G
Guest
Guest
All, I am wrestling with what temperature of the coolant in intake manifold I need to be turning on the radiator fans. For those who have run a GT40, what has been your experience with this??
I found a 195° temperature switch from a late model mustang to put in the intake, but have been unable to find a lower one. My temperature gauge sender is bad (ordered a new one this morning) and I have wimped out before letting the engine get hot enough to trigger the fans since I don't know the temp for sure . I tested the switch in a pan of water, which is how I figured out the gauge sender was bad, and it did turn on. I understand that SPA makes and adjustable temp switch, but I want to make sure that I am not being paranoid before buying it.
