Go Back   GT40s.com > GT40 Replica Manufacturers' Corner > RCR Forum - RCR40 /SLC / P4 / MKIV > The SLC Clubhouse
The SLC Clubhouse RCR SLC Build Logs and Technical Questions
Old 28th April 2012, 12:04 AM   #1 (permalink)
Dlampe's Avatar
Dlampe
oil cooler mount pictures?
I need to mount my oil cooler and I was wondering where you guys have mounted yours? Pictures would be helpful.
Thanks!
Dlampe is offline
Old 29th April 2012, 02:48 PM   #2 (permalink)
shark's Avatar
shark
3 Tenths
GT40: SLC/LS3+/G96.50
Re: oil cooler mount pictures?
Dean - I'm sure there are better pictures, but if you look close you'll see some coolers/fans.
ID:	58625   Click image for larger version
Name:	Rear Bay-coolers.jpg
shark is offline
Old 29th April 2012, 03:18 PM   #3 (permalink)
molleur's Avatar
molleur
GT40: SL-C LS1/930LSD
IMO, the best spot for a cooler is in the side scoop area, unless you have the side exhaust. You will have to fab some brackets anyway. With the Ricardo gearbox the room for a rear mounted cooler and exhaust is limited. Anyone else care to chime in?
molleur is online now
Old 29th April 2012, 08:17 PM   #4 (permalink)
Dlampe's Avatar
Dlampe
I mounted the cooler today. I put it in the scoop area sort of. I have side exhaust so I had to really tuck it up out of the way. I will add a heat shield once the body is mounted for the last time. There was no way to mount it in the rear where the factory car has them mounted. My cooler is larger with a fan.
Thanks for your help.
Dlampe is offline
Old 30th April 2012, 05:05 PM   #5 (permalink)
rockhopper1970
GT40: SLC in process
Dean, I mounted mine like the race cars but I turned them 90 degrees so the top is towards the front of the car. it seams like it will vent better that way with the street tail and wing
rockhopper1970 is offline
Old 30th April 2012, 05:17 PM   #6 (permalink)
Dlampe's Avatar
Dlampe
Can you post up a picture?
Dlampe is offline
Old 4th May 2012, 02:10 PM   #7 (permalink)
rockhopper1970
I'll try
Old 4th May 2012, 02:15 PM   #8 (permalink)
rockhopper1970
Here it is
Name:	trans cooler.jpg
Old 4th May 2012, 02:16 PM   #9 (permalink)
rockhopper1970
also dean, did you figure out which ricardo line is going out of the trans?
Old 4th May 2012, 02:20 PM   #10 (permalink)
Dlampe's Avatar
Dlampe
I am running the 997tt 6 speed, not the Ricardo. Thanks for the picture!
Dlampe is offline
Old 4th May 2012, 02:21 PM   #11 (permalink)
rockhopper1970
also check out exterior mount to reduce cooler stress
Name:	cooler mount.jpg
Old 4th May 2012, 03:12 PM   #12 (permalink)
WMM
GT40: SLC
Originally Posted by rockhopper1970 View Post
Here it is
Rockhopper, I see you are using the street tail and noticed the two aluminum plates that extend past the ricardo, parallel to each other. What will attach to the ears at the ends? Got me wondering.
WMM is offline
Old 4th May 2012, 03:24 PM   #13 (permalink)
rockhopper1970
Wing mounts, I go to VIR to play on the track for member days, but I wanted to drive my car on the steet as well so I told Fran to set me up similar to a GT3 RS so he picked out what would be the best options for that. Unfortunately they did not tell me that the tail would not swing up with the wing mounts in place, so they are working that out, they say they will have a answer in a couple of days. Currently you have to lift the tail off the car, not good for checking the engine out for leaks or fire by yourself.
If you have the race tail, you should mount your coolers like Frans. with the street tail they flow into a dead space, but with the race tail they work great where he has them. I still think the outside of the cooler needs a brace so it doesn't strees fracture itself to failure.
Old 4th May 2012, 04:58 PM   #14 (permalink)
wbmusarra's Avatar
wbmusarra
I Have No Life
GT40: DRB#5
If you just want the tail off in your garage to do repairs or general work, you can do like I do since I have no one to help remove the tail of my 40. Some 2-3"cotton tie down straps and an engine hoist work well together to lift it and place it out of the way. Its amazing what you will think up when there isn't any help around.
DRB#5
351W/392 DIS TWM F. I. 930 Porsche LSD
wbmusarra is offline
Old 5th May 2012, 03:34 AM   #15 (permalink)
EFNFAST
I Have No Life
Canada
GT40: 917, SLC, Cobra
The diffuser is in the way, unless you put the cooler inches from the ground in the rear?
EFNFAST is offline
Old 5th May 2012, 06:34 AM   #16 (permalink)
rockhopper1970
Still want to hinge it. If there is a fire you will have a heck of a time getting to it, first car I saw was John Salmons. His opened easily, so no reason mine shouldn't.
Old 5th May 2012, 06:36 AM   #17 (permalink)
rockhopper1970
Alex, so the race tails aren't like Frans race car?
Old 5th May 2012, 08:52 AM   #18 (permalink)
Dlampe's Avatar
Dlampe
The race car ran the street tail last year but this year he is running the race tail. I believe those pictures above are for the race tail set up.
Dlampe is offline
Old 5th May 2012, 09:02 AM   #19 (permalink)
Fran Hall RCR
gt40fran's Avatar
gt40fran
Sponsoring Vendor
GT40: Michigan,USA
You are all right...a bit.
Last year on the 01 race car we ran the street tail with the lower street diffuser section removed ....no need to hinge the tail on a race car...it needs to be removable....
This year we are running the original "race" tail section that we designed for the SLC and the rear wing...commonly know as the race tail....this tail is also removable on the race car...again no hinges....when used on a street car this tail hinges and the rear wing does not interfere with this hinging action.
John Salmons car has the same tail...the original race tail....and his tail hinges as he has a street legal car and may one day use it on the road....he can leave his rear wing in place and hinge his tail without issue.
Rockhopper has the "street tail" with the lower diffuser AND the rear race wing....but the rear wing interferes with the hinging of the tail.
Rock hopper does not want a removable tail as he wants to be able to single handedly open the tail and service his car when at the track...currently the only way to do this is to have the rear wing on quick pins, to make it easily removable and then put slots on the tail section that enable the tail to hinge past the wing mounts...
We are playing with a design that will enable the street tail to hinge AND the rear race spec wing to be used but its always going to be a little of a compromise..
Hope you guys can follow all that...phew..
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF
gt40fran is offline
Old 5th May 2012, 10:17 AM   #20 (permalink)
rockhopper1970
Thanks Fran
Similar Threads
oil cooler Paul Bearman The Garage Sale 3 26th November 2008 12:58 PM
Oil cooler thermostat? Bigblockquad GT40 Tech - Powertrain/Transaxles 2 22nd February 2008 07:17 AM
Engine Oil Adapter, Remote Oil Filter / Cooler Ron Earp GT40 Tech - Engines/Induction/Exhaust 10 24th January 2008 09:12 PM
R21 Cooler system pictures ? Howard Jones GT40 Tech - Powertrain/Transaxles 18 10th March 2007 07:59 PM
Oil Cooler John Preisig GT40 Tech - Engines/Induction/Exhaust 0 18th February 2003 04:26 AM
