Hi,
I've been lurking on GT40s.com for years, before I ever knew what an SLC was, but decided to break my silence today. I've been interested in building a mid-engined component car for at least 10 years.
I currently own a Lotus Elise that I've completely pulled apart and put back together twice over the last 3 years. It has an aftermarket TVS blower on its tiny motor and is quite fast! But it's tiny, and is a bit twitchy, and I love the way it drives.
Anyhow, I am considering building an SLC for my next car, although the 917 is my all time favorite car and RCR does make a nice kit, and an LS motor fits, I am guessing that the SLC is a better actual car.
Questions regarding the SLC:
I've never seen the method of construction for the SLC's chassis discussed, but most aluminum monocoque chassis I've seen or read about were made by bonding sheets and/or extrusions with epoxy and rivets since you can spread loads over the entire interface between bonded components, and retain the annealed strength of the original materials. My understanding is that SLCs are constructed of TIG welded sheet aluminum; how does this compare for fatigue and strength, specifically around the welds, over time to a bonded aluminum chassis?
What is the ride height range for acceptable suspension geometry? And are lowered uprights available?
Can someone post a picture of the underside of the car? I am guessing it is flat, but I've never been able to find a picture. Has anyone attempted to make ground effect tunnels for the rear underbody work, or are there frame components in the way?
What are common options people generally get when ordering a kit?
I'm guessing the grazziano transaxles are like $10Kish +; how do these compare to inverted Porsche transaxles for durability and feel? The Toyota C6x that is in my Lotus is far from my favorite transmission I've had (favorite would be on my 1st gen miata!) and I'd like my next car to have a more rewarding transmission.
I'd probably do an LS376, and this would probably see some track use. Would you recommend a dry sump for a streetable track car, or would an accusump and baffled pan be sufficient? I'm not too familiar with LS motors and their oiling.
I think that's it, thanks for reading!
Rich
Rich
