Atleast at that price it better be! I'd hate to see the cost if I didn't have a master machinist friend :lipsrsealed:
I designed everything (except the quick release pin obviously, heh) and he cnc'd it.
I think the primary advantage a setup like this has over the aero-catches is that you can remove/replace the front and rear clips however you like - at an angle, up and down, whatever, because there's no hammer-stud ramming down.
Pin goes through the support bracket
Through face plates (with studs machined in - note - don't bother trying to countersink 0.06 (thinnest material you can use since you need 2 face plates to cover the holes) material for #8s ... the plates wobble around too much
Into a threaded plate
With a cnc'd spacer and jam nut
When put together, due to ride height, he's invisible unless you really crouch down, but at that point you'd see the aero-catches, so visibility (invisibility) is a draw
Alexisisisisisisis, re-inventing the wheel just because :stunned:
