Activepower gt40 C5 rear suspension points?
Hey lucky Active power gt40 owner/builders, I've been eyeing up your rear chassis C5 suspensions as I need direction with my Manta rear C5 conversion. It looks to me like the lower and upper control arm mounting points are both mounted level front to rear . Am I seeing things or is that how they actually are mounted?
2 x2 rear cradle is what my Manta has currently and replacing it with a similar 2 x 2 with level control arm mounting points will really simplify things. Thanks I appreciate any direction.
I apologize if my reposting these pics I've found on Active powers site ruffles any feathers-just posting them so others can eyeball what I'm talking about.
Though you asked for active power, thought having GTM points would help too. These are from CATTRAX on a F5 forums. I seem to recall that GTMs and GT40s have similar track widths.
Front.
X Aft Pos Y lateral Z height
Lower Arm: Front Pivot 10.75 12 7.375
Lower Arm: Ball Joint 14.5 29 5.5
Lower Arm: Rear Pivot 24.25 12.5 7.375
Upper Arm: Front Pivot 10.625 17.5 18
Upper Arm: Ball Joint 15.375 26.25 20
Upper Arm: Rear Pivot 20.25 17.625 18.125
Wheelbase 101 Track 60.5 Tire Diameter 25.3
Steering
Steering tie-rod outboard 9 28.625 10
Steering tie-rod inboard 10.375 13 10.75
Auxiliary
Spring upper on chassis 15.25 17.25 21.375
Spring lower on suspension 15.25 24 9.25
Spring attaches to: x Lower A-arm Upper A-arm
Shock upper on chassis 15.25 17.25 21.375
Shock lower suspension 15.25 24 9.25
Shock attaches to: x Lower A-arm Upper A-arm
Rear.
X Aft Pos Y lateral Z height aft adder 127.25
Lower Arm: Front Pivot 112.5 10.375 8
Lower Arm: Ball Joint 115.5 28.5 5.375
Lower Arm: Rear Pivot 124.75 11.125 5.625
Upper Arm: Front Pivot 116.75 16.125 18
Upper Arm: Ball Joint 116.25 26 20
Upper Arm: Rear Pivot 126.25 16.25 18
Wheelbase 101 Track 62 Tire Diameter 25.35
Steering
Steering tie-rod outboard 121 28.5 9.375
Steering tie-rod inboard 121.25 12.75 10.875
Auxiliary
Spring upper on chassis 112.5 18 22.5
Spring lower on suspension 112.5 24.5 9
Shock upper on chassis 112.5 18 22.5
Shock lower suspension 112.5 24.5 9
