Jim Rosenthal
Having found templates for the fuel tanks, I think I am going to try to get aluminum tanks made up for the GT40. Some questions, since these will more than likely get made by the metalworking shop that is doing most of these custom parts:
-what are aluminum tanks made of- what alloy, and how thick?
-where do the baffles get placed? are there baffles around the sender?
-the tank would need a fill, an opening for the sender, a fitting and downpipe for the fuel pump suction line, and a vent- anything else?
-where does the vent get vented to?
-we're going to try to do without the foam that goes inside fuel cells, since my understanding is that it degrades faster than ever with alcohol mixed fuels...and when it degrades, it ends up in the fuel system.
I don't think I can get plastic tanks made up at a reasonable price. I'm satisfied that aluminum tanks will be okay if they are kept clean, and that water is kept out of the fuel. This application is not the same as a boat, where I wouldn't have aluminum tanks on a bet.
Clearly I know nothing about all this, so any advice is appreciated.
