Bobs GTD
Hi Bob
Very nice, just one remark from my side.
Put the MSD inside of the car it is in no way waterproof. I have bad experience with it as it sucked up water and made a shortcut, totally destroid.
The second one ( as for wireing reasons I can't change the location now) I opend up and sealed it with silicon but I still cover it with a bag on very rainy days or during washing the car.
Carlos
Carlos,
Excellent advice I will make a water proof cover for it to seal it up. I don't really want to put it inside the car no room as it is in there plus then you have to seal the holes to it.
Thanks,
Bob
Ha All,
I was able to get the throttle linkage done this weekend, what a pain in the a** that was but its in and works ok.
See Ya,
Bob
Ha All,
See Ya,
Bob
Hi Bob,
if you are going to route the cable over or close to the exhaust it will melt away.....
What I did to prevent any contact is, I just placed the cable as it is into a aluminum tube, and made a big loop over the exhaust so it stays away ....The tube ends in the center tunnel, and has some supporting brackets
skeleton
Skeleton,
Yes I'm sure I will have to do some final adjustments to the cable but I'll wait to do that after the headers are in the car, because my headers don't look or fit exactly like yours do, but thanks for the input and keep checking on the progress.
Bob
Or you could turn the carb around and have the cable come in from the front..
Nice work Bob!!
Cheers All,
I was going to get my rear sway bar ready to mount but when I looked at the ends I was disappointed to say the least. Who ever did this used little wimpy 5/16 " threads and they weren't even in the center of the shaft. So I got the mill all set up and modified them to accept a 1/2"-20 tap and new heim ends and there you have it, A lot beefier set up than the original. that's it for now.
See ya,
Bob
Ha All,
Got the rear sway bar finished just needs powder coating, and was able to get a good start on wiring the dash. That's it for now.
See Ya,
Bob
Ha All,
I was able to get to my buddy's shop on Friday and spend 3 days working on my headers. Unfortunately I ran out of J bends on Sunday or I mite have finished them, I guess next weekend is going to have to do, I ordered more J bends and will finish them than. I used the IC engineworks kit to mock up the tubes, boy does that work slick really helps take a lot of guess work and trial and error out of the equation. After they are finished they are going to be ceramic coated and finally put on for good. I'll post more pics next weekend when finished, so far about 22 Hrs. in them
See Ya,
Bob
Ha Again,
Well its snowing like crazy here so I was able to get my door seals finished today, I'm not crazy about the foam look so I did mine a little different.
See Ya,
Bob
Ha All,
Well my headers are finally home and ready for fitment to the car, and from the pics attached you can see that they fit quite nicely. Tomorrow I will finish weld them and then they are off to get ceramic coated then finally put on for good. This was quite the undertaking but I,m very pleased with the way they turned out. If anyone is interested I have 35 Hours invested in them and about 200 bucks in j bends. I'll post more pics when they are ceramic coated but for now got to go.
See Ya,
Bob
HI Bob Have you had the rear clip on with these ???? I had to remove all the strait pipe from the collectors to shorten the exhaust to clear the clip when tilting it up. Lookin Good. Wally
Ha Wally,
Took a few pics with the rear bonet on to show that it does work, I set this up long before I made the pipes so I was confident that it would work. Thanks for the concern its always nice to have another set of eyes look at something just in case you miss something.
See Ya ,
Bob
Ha All,
Well I was rather busy this weekend and got a lot done. It is presently snowing here in Wisconsin, expected to get 12 to 18 inches of snow so I have a little time to post. I mounted the flywheel and the clutch finished mods on the adapter mounted the starter built the bracket for the slave cylinder and got the LED taillights back and mounted. Please check out the pics and I'll see ya later.
Bob
Ha Again,
Well I finished the rework on the E-brake system, it is now on both rear calipers like it should be. I also finished the clutch slave cyl. mounting just need to send the bracket out for blue anodizing and it's done, That's it for now
See Ya,
Bob
OK so I changed my mind, I was just going to clean up the slave cly. bracket a little for anodizing but when I got to look at it I decided to just keep on polishing and there it is done.
See Ya,
Bob
PS check out the reflection of the camera in the picture, pretty cool.
Ha All,
Well once again it's snowing like crazy here so I have time to get caught up with my build thread. Anyway I got my VDO speedo sender modified and installed on the trans. this was a standard GM sender and with just a little machining on the outside and it fits and works well. I also was able to get the trans. oil cooler mounted. The first of the interior dash switches are mounted the ignition switch and the start button. The last thing I got finished was the interior engine cover, I was able to get sound deadening and heat barrier in the cover. Well that's all for now time to go plow snow!!!
See Ya,
Bob
