Thanks Chris
The rack has yet to be chosen and which everyone it is will most likely have to be modified.
This is what I have found to be the typical rack & pinion 2.5 turns lock to lock.
from a GT 40 builder
The steering rack that I used was from the Ford Cortina and all that is necessary to get it to fit is to cut about ½ inch off each threaded end to reduce the overall length by 1" , you can use the steering rack from the Ford Escort but that needs extension pieces made and fitted as it is too short as standard. Many other racks could be used and the only criteria is that they are the correct length, can be made to fit the track rod ends which have to be suitable to fit the Ford Granada uprights. You have to position the steering rack so that the steering column can be easily coupled and to avoid bump steer. Some might not know what "bump steer" is, well its when the wheels are steered by the suspension as it moves up and down, this is obviously an undesirable feature. The reason for bump steer is basic geometry and I won't go into that as I'm sure you won't want to start remembering all that from your school days. As neither the Cortina or Escort racks are exactly correct for the geometry (and I don't know of any rack that is exactly right) you have to position the rack so that you don't get any significant movement of the steering over the range of suspension movement that it will be working over. This should only be around 3" of vertical movement and not the total movement that the pivots will allow. Offer the steering rack up and fit the track rod end to the uprights and then move the suspension through the movement range that is required and check for bump steer movement, when you have this correct note the steering rack position and plan the mountings to suit. The mounting that I added for my steering rack were supported off the lower chassis members but again in hindsight I should have mounted them from the upper chassis members as that would have given me more space for the pedal assembly to be fitted later.
balance is good Ian, not way to the right and way to the left,,, all or none is not the way am going ...LOL your cracking me up with the citroen... I could also get with the low riders out here! They have some trick stuff also..
In theory the Brakes will be antilock servo with bias control front to rear. Power assist and adjustable pedal force would be good.
It will be fun asking you folks about the electrical system design...
