Hi All,
At the stage of sorting the axles on my McLaren M1C rep - which uses 930CVs at both ends, a 930 transaxle, and suspension of period design. Maximum axle length is at shock-limited full droop, minimum is at ride height and is about 12mm shorter.
Measuring the CV assembly centred and at zero angle the CV inner section that receives the axle is 4mm thinner (2 each side) than the CV outer main body, meaning that the theoretical circlip to circlip length on the axle is about 4mm shorter than the measured flange to flange distance. I'm assuming the CV centre stays central to the outer as axle angle is introduced.
I'm not sure how much extra length is customary to provide over and above this theoretical value, but it would be nice if 10mm were acceptable as that would accommodate all likely suspension adjustment and the slight left side to right side variance I have. This would mean nearly an inch of float at ride hight - there is enough depth for that but unsure if it's excessive.
I'm also planning to have my axles made up from a set of heavy duty porsche axles I have that are too long - I helped a friend with a cobra build and he had a jag IRS narrowed by cutting and shutting the halfshafts - Circle Track Engineering in Christchurch did the job and the result looked great and has been reliable. The axles I have neck down to 26mm and the finished result will be about 365mm long - is a cut and shut procedure valid from a strength and fatigue perspective?
Keen on your advice on both determing length and axle mods.
Cheers, Andrew Robertson, Wellington NZ
