turboman808 said:
I'm not sure what the difference between a dry sump and a wet sump is. I am assuming a dry sump means the oil is not stored in the motor. But then if thats the case then what is the difference between the normal oiling system and a wet sump. But yeah I am not sure.
As you say, the oil os not stored in the 'sump' in a dry sump setup.
Instead a scavenge pump is used to - well - scavenge the oil from the dry sump pan
This scavenge pump pumps the oil to a remote oil tank.
A second pump is normally used to feed the oil to the engine. In some setups this is the standard pump but with its input pickup pipe replaced with one that takes oil from the remote oil tank. Other arrangements use an external pump and feed the oil in through the oil filter plate (filter may be mounted remotely as a result).
I would have a look at the aviaid.com web site, as there are some good descriptions of how the system works in most configurations, but they do differ depending on what engine, and what application.
[/QUOTE]
But the big question is if you run a dry sump can you in fact lower the motor and transmission? When I got my first porsche I was very impressed with the dry sump system and how the motor was at the lowest point in the car.[/QUOTE]
Well the Porsche is a good example of the setup. You will no doubt be familiar with the large tank mounted in the right rear wing.
Onb a small block the dry sump can be significantly shallower than a wet sump, so yes, you can mount the engine lower. Just how low though is determined mainly by the size of the flywheel/bellhousing, and to get the driveshafts set at a neutral angle.
The main advantages of dry sumping are:
- shallower sump, allowing better engine placement,
- larger oil capacity, meaning better oil life / temperature control
- no oil surging / pressure problems (if a proper tank is used...)
- in the case of lemans, being able to meet requirement to run for 24hrs without topping up oil
To be honest I'm not sure dry sumping is required for road use, unless you see high oil temperatures in normal road use. For racing though, if you can afford it and have room for all the bits like the pump, tank, remote filter etc, it is well worth the money.
Hope that is of some help.
Cheers,
John (dry sumped 427 side oiler)
