Mike Pass
The info I have is below
Granada Mk3 Scorpio hub nuts
(Same as ford sierra/escort cosworth part)
Spanner size 41mm Thread size 22mm x 1.5mm
Right hand thread Ford UK Part number 6133688
Ford USA part numbers
LHT: E822078S100
RHT: E822077S100
6133688 (E822077 S100) O/S is Right hand thread
6133689 (E822078 S100) N/S is Left hand thread
If I remember correctly the nuts are41 across the flats.
I got mine from Ebay
When I rebuilt mine I used SKF bearings.
The complete thing is available on Ebay here
FORD GRANADA STUB AXLE CV JOINT (SET) & HUB NUTS 100MM (BRAND NEW) | eBay
If you just need the nuts the local Ford dealer should be able to get them as I have got them from them before. Or an internet trawl will bring them up at various motor factors. They do need to be very tight 200 ft.lbs torque. I use a 3/4" torque wrench which is about 4 feet long and rest the extension bar on an axle stand.
LHT: E822078S100
RHT: E822077S100
