I'm stripping down the GTD I have bought with a view to rebuilding it with a 302 in.
the fuel tanks are NOT standard GTD, they have been built by an outside engineering company. Before I re-install them, I want to check that the pipe size is ok for a mildy tuned 302.
The fitting is on top of the fuel tank with a connection for goodrich braided hose to the fuel pump. The INTERNAL diameter of the fitting is 4.18mm and the INTERNAL diameter of the pickup is 6mm.
Is this going to be ok to supply fuel to a 302 engine running a 600cfm holley?
Simon
Simon
