I have mounted 12.13 X 1.25 wilwood rotors and superlight 2A calipers(4 pot) all around. Have retained stock GTD boosters and master cylinder. Rear has proportioning valve in line. Rear brakes all OK. Fronts seam to drag slightly and SREACH to allmighty heaven all speeds all brake rate.
I seam to remember someone putting a residual pressure valve into the front brakes with this setup but the "search" did not turn up much .
Any advice? If I put one in the front line do I put it between the output of the booster and the calipers, or between the MC and the booster.
How about pad type? I have some agressive race types in the front now. Shound I put in street pads?
Thank you in advance, Merry Christmas!
