Now apart from rebuilding this carb - i suppose I might as well, now I have got this far - or would you recommend "it aint broke - dont fix" - or an exchange one (£200).....
Holley 750 cfm 4 barrel “4160” Carburetor
Richard, what is the displacement on the motor you're using? If it is a standard 302, I'd be very careful before I replaced that 600 cfm carb with one a full 25% larger. Bigger is not necessarily better on the street, same goes for mechanical secondaries. If it's a 351 or a stroked 302, well, you might just have enough displacement for the larger carb....it's a gamble and an expensive one at 200 pounds per carb. I found that my mildly modified 351 Cleveland ran better with a 600 CFM Holley than with a 780 CFM Holley, size DOES matter in this case.
What is important here is how your carb "senses" demand, it's based on the "vacuum signal" at the venturi, which is EVERYTHING when it comes to getting the fuel to flow through those metering blocks and the passages in the carb. Larger venturi=lower "demand signal", which really messes with the fuel delivery and can create much larger problems than a smaller carb, which will more accurately sense the demand. Simple explanation for a much more detailed problem, hope it helps.
If you do find that the carb must be replaced, however, what might help you more than a larger carb is a carb of the same size but with center-hung floats. If you do much spirited driving on twisty roads or track your GTD, you might have noticed some fuel starvation coming out of tight corners...that's a function of having the hinge for the float in the fuel bowl hung on the side of the bowl housing. If you can find a Holley with center-hung floats in the correct CFM range, you'll find it much more responsive in that regard, won't make much difference in straight-line accelleration, though. An added bonus is that the center-hung floats can be adjusted while the engine is running.....no need to take the bowl off and check the float's adjustment :thumbsup: .
I'd agree with Randy, get those vacuum leaks plugged, put in a new PV, put it back on and get the timing set right and see what happens......that carb might very well just be sooty on the outside from the backfiring and other malfunctions.
One other thing, in the future when you plan on letting your car set up for such a long period, I'd suggest you find a way to run it dry on fuel. When petrol evaporates, it leaves a very nasty residue (often called shellac) that tends to plug things like little orifices up.....I usually run the car as low as possible on gas and then find a place where it can idle safely until the carb runs dry. Even then, I tend to back off on the bowl screws a bit, "drain" the fuel out of the bowls, and then tighten the screws back up. The car will stall when the fuel gets below the level of the jets, which in a Holley is pretty low, but better no fuel than even a little during a storage period.
Doug
