So far the mono version is the direction I want to go, it's just a lot of fitting and fiddling and very limited info to work with. I have to completely redo all the panels as the current ones are too soft of an alloy.
Planning the original style 49,( R2 ) with green / yellow colors, no wing, with two possible drivetrain choices.
My first choice is a DFV or DFR coverted to DFV look. I am also working on a small block 289, which will have Inglese injection, with proper inward tilt on the trumpets, and valve covers I am fabricating which will look identical to those on a DFV. ZF transaxle, which is what the first few had before changing to Hewlands.
Either way I am looking for at least 95% accuracy in appearance, and a usable track car, not a static display. Definitely something to look forward to during the winter months instead of snow.
Mick, any pictures you have would be much appreciated, that is one area I am lacking in for the fine detail.
I will try to post from time to time with updates.
