Seymour Snerd
FYI: I measured the Aviad wet sump on the installed FE and the lowest point is 6" below the front bottom edge of the block that puts the front of the pan 1" below the underbody (about the same drop as the lowest point on the bellhousing).
Steve -- Thinking about wet-sump pan choices I'm getting a little confused trying to correlate all the measurements.
In an older post you said "I have the same clearance Frank Catt mentioned above (80mm to the ground) at front of oil pan...FE engine sits level ... the bottom of the bellhousing is just about in line with the underbody the Avaid oil pan although flush with undercarrage in rear sits lower in front..... "
Two things: did your bellhousing move at some point since in your earlier post it was "about in line with the underbody?"... I'm thinking of that rear transmission mount that you installed later; could installing it have caused the bell housing to drop an inch or so? (seems unlikely unless you discontinued the crossmember mountings at the same time)
Also, are you sure the engine itself is level and the pan is not? I ask because on the originals (w/ T44, etc.) the front of the engine was about 1" higher than the rear (slope about 10 degrees) so there is some precedent for non-level engine.
Looking at the 155-55410 pan on the Aviaid site I can't tell if it's "parallel" or not (it's listed as 6" deep). FWIW Armando makes a similar pan (408) but his is listed as 5" at front 6" at rear. So I'm wondering if your Aviaid pan is like the Armando but sloped the other way.
OR more interestingly if your is pan is in fact "parallel" at 6", and your engine sloped, then the Armando pan would neatly increase your pan clearance by 1" and make the pan surface coplanar with the underbody.
Can you check any of this?
Thanks,
Alan.
