I hope so I have a car on order should be done by Dec. Their production run is about a car a month.
Alan
Hi Jeff,
#176. Why CAV? It all comes down to personal tastes and what you want out of the car. I’ve been dreaming of gt40 since 2002 and have had a lot of input. I’ve driven SPF/RCR/CAV, been to club events, talked to owners etc. IMO What I’ve always like about CAV is that it has a lot of little options that make it more streetable/production car like. Rear glass over the engine and in the bulkhead not plexi-glass, doors close like a production car, rubber door seals are great, no black plastic eyebrows, ride quality, power brakes, separation between driver and passenger, body shape (SPF/RCR/CAV) are all little different, front sway-bar doesn’t hang down, I don’t care if it’s a continuation car or not to me a replica is a replica not a original. Again this is my taste everyone is different all of the manufactures make great products and it depends what’s important to you. My recommendation is to drive all of them, spend some time with the owners.
Alan
Jeff,
The color will be 2007 viper blue with twin white stripes, wide body, 17 inch wheels 12rear&8.5 fronts. Drive train will be ZF transaxle (ZFQs are out of production), 438 cid SB aluminum dart block, solid roller lifters and port fuel injection 630hp. I’m sure I will end up putting a racelogic traction control on it. I will be running 4 to 6 track days a year then drive the heck out it on the street. Cool feature with CAV if you run fuel injection they will put a balance pipe between the two fuel tanks so that you only need to run one fuel pump and never need to switch between tanks.
If you want more details PM me…
Alan
Jeff,
Alan
Alan, why such a small engine? Aren't you going to need more power than that?
After all, those new ferrari 458s at your track events have less power and 1,000 lbs more weight. They might be able to keep up.
Cheers.
