Kva fuel tank mounting?
Hi,
Anyone got a pic of the way kva "c" fuel tanks are mounted?.
Got access to mine to remove and clean, but can't see how they are fixed.... And don't want to derivit the whole car A pic or drawing or guess would be appreciated
Succesfully removed me KVA fuel tank. see pics attached. The top sheet on passenger side need to be removed. Then you can remove the bolts hanging the fuel tank into the frame. The construction with the bunch pf nuts is a bit wired. Will change that upon remounting with tow screws to fix to each side of the frame.
