Casey, can you tell if the ball joints on your CAV bind with suspension movement? I have mono#8 and there seems to be lots of range of movement for the ball joint w/o binding.
I think what Jean is saying above is that the flaw is the block bolts rather than the block or ball joint or upright or other suspension element. Specifically, the use of below-grade bolts (8.8 or below) and short bolts creates an issue, the fix being to use 12.9 or better and lock tite those babies down good!
