FS USA Mighty Demon 750 cfm Carb
This is a slightly used Mighty Demon carb Part # 5402010GC, 750 cfm, 4 x 1.69" butterflies, mech secondary, that was used for an initial dyno tune on a 418W.
$350 plus shipping from Colorado.
Currently selling at Summit for $597.
From Summit Racing.com:
Are you running an over-the-top street/strip engine combo with a high compression ratio, big cam profiles, large cylinder heads, etc.? If so, then you need a radical street/strip carb to match. Demon Carburetion's Mighty Demon carburetors are a step up from the Speed Demons. They feature billet base plates and metering blocks, concentric venturis, replaceable air bleeds, mechanical secondaries, and fuel bowls with sight plugs. They're designed for engines with camshaft profiles up to 260 degrees at .050 in., large cylinder heads, large intake manifolds, and higher compression. For race engines and high-output street engines, the Mighty Demons deliver the best performance value for the dollar!
Demon Fuel Systems - Specification Charts
