FS USA 625 (650) Road Demon Carb
625 CFM (flows more than that they claim) Demon carb. Road Demon type, so vacuum secondaries and provisions for electric or mechanical choke (no choke installed). Also includes the secondary spring kit for tuning the secondary opening point. In good shape, was working fine when pulled and performed well. You'll need to check floats after shipping to make sure they are right but otherwise it should be a bolt on and drive for a mild 289-351" motor.
$230 USD shipped anywhere in the lower 48.
Description:
Styled and calibrated for Street Rods and mildly modified Street Machines and light trucks, the Road Demon™ is an impressive performer. With a remarkably smooth choke tower design, vacuum secondaries and patented air entries, the Road Demon™ offers extremely smooth operation with strong throttle response. The Road Demon™ has the standard Demon carburetor features: Max-Density Cast metering-blocks with adjustable jets and four-corner idle, a billet baseplate, plus large capacity fuel bowls with patented sight glasses for tuning ease.
The Road Demon™ 625 targets mild performance engines from 302 to 400 cid, and rated at 250-350 horsepower.
Features:
  • Max-Density Cast Rib-Reinforced Baseplate
  • Max-Density Cast Metering Blocks
  • Four-Corner Idle Circuitry
  • Large Capacity Float Bowls
  • Large Glass Float-Level Sight Windows
  • Integral Hi-Flow Choke Housing
  • Dual-feed Inlet
  • Vacuum Secondary Operation
  • Power Valve Backfire Protection
  • "Quik Release" Non-Stick Gaskets
  • Vacuum Fittings
  • Most common tuning parts interchange from other manufacturers
    (jets, power valves, gaskets, etc.)
  • Quick-change Vacuum-Secondary Spring Cover
Pic added.
