NEW Ali Dart 427 engine and new RBT ZF gearbox.
I have the following for sale:
Ford/Dart 427 Engine Kit to make an easy 550BHP
Dart alumium block
Scat steel crank
Champ dry sump
Paterson dry sump pan
Diamond custom piston rings
AFR CNC ported cylinder heads
Edlebrock Victor Series intake
Tal ali rocker covers
Shaft mounter rocker gear
ATI super damper
Holley 950 double pumper
Full felpro gasket set
Comp cams roller cam
Comp cams roller followers
Ali front cover
Victor Series water pump
SVO Ali pulley set
Oliver Rods
SVO timing chain set
ARP Engine bolts
ARP Engine damper bolt
ARP Cam bolt
Moroso spark plug leads
MSD billet dist.
MSD 6T ign.
Full felpro gasket set.
Brand new ZF/RBT Gearbox
Ratios:
1st 2.58
2nd 1.61
3rd 1.14
4th 0.846
5th 0.704
Diff is 3.22 and is LSD
£17,500 for both the engine parts and gearbox.
Or £6500 for the gearbox and £13,000 for the engine parts.
J.P
James,
I would be interested in the engine parts and have sent you a PM with my phone number. Perhaps you could give me a call.
Miles
