Just in case anyone cares, here is a list of the bolts and their associated washers and nuts I used when I switched over to AN fittings...
Front suspension:
AN8-26 for upper front wishbone, upper and lower damper mounts.
AN8-42 for upper rear, and both lower wishbone mounts.
Rear suspension:
AN8-26 for the upper damper, NAS1306-54 for the lower damper (could be a -53 but I couldn't get my hands on any), AN8-50 for the upper arm to the hub, AN8-34 for the lower a-arm at the chassis, AN6-34 for the lower a-arm rear at the hub, AN6-22 for both upper and lower trailing arm rears, and AN8-27 for both upper and lower trailing arms front.
Plus you need at least 2 washers for every connection (that worked out to 28 AN960-816 for the 1/2 bolts, a couple needed an extra washer, and 24 for the AN960-616 washers). Then the nuts are AN365-820 for the 1/2" and AN365-624 for 3/8". For the NAS1306 bolts I used NAS21042-6 nuts.
All the AN stuff came from Aircraft Spruce and the NAS came from Coast Fabrication.
Or am I just alone on this one?
Front suspension:
Rear suspension:
