The marine fuel valve from Pollak, listed as a "Standard Ignition" part number, is an "FV6 Fuel Valve". You should be able to order this from a NAPA store (if you're a Yank).
Gary, It's a three port. As used in a boat it would have two tank feeds into a shutoff valve at the carb. I'm using it to divert return fuel from the overflow in the fuel surge tank. Left fuel pump on means we return to the left tank. Right fuel pump, right tank. I wanted to avoid putting 16 gallons into an 8 gallon tank.
I have two low pressure fuel pumps feeding a surge tank through filters and one-way valves. A high pressure pump picks-up at the bottom of the surge tank, circulates fuel through another filter and around the fuel rails and to a fuel pressure regulator which dumps back into the surge tank. Overflow from the surge tank goes back to the tank which is supplying the system.
Once I have the prototype debugged I suppose the shop where I get things made can build more tanks if anyone needs one for an ERA.
