Lynn Larsen
Lynn Larsen
I had originally spec'ed a set of Jesel Sportsman shaft mount rockers to go on my AFR 205s. But, as you all know, I've had to reduce my motor budget. Probes can be bought for right at $500 where as Jesel and Harland Sharp SMRs go for $700. Crower's and T&D start at ~$1K. So, I'm thinking that the Probes are certainly more in line with my pocket book and I'm thinking that SMRs, even Probes, will be more stable at higher RPM than any stud mount rockers.
I've looked on a couple of boards and have found precious little about SMRs in general. Mostly just, "Go with Jesel." The only thing I found was 3 years old and said the Probe bearings had crumbled (Probe uses a pair of 1,100 foot pound capacity Torrington captured needle bearings now.) Has anyone here had any recent experience with Probe's product? I found a guy who has a set of used Jesel Sportsmans for $500, but they are for Vic Jr. heads and will probably need to be shimmed, but should work. Several vendors have the same part no. for Vic Jr. and AFR. Any other words of wisdom on shaft mount rockers?
Thanks,
Lynn
Thanks,
Lynn
