Hi guys,
There are only a handful of qualified ZF mechanics in the USA; one of them is Les Gray, a good friend of mine. He used to be the ZF guy for Hall Pantera, and more recently he has been maintaining the gearbox for Jim Click on GT40 P/1061, among many others. He's located in the Phoenix, AZ area. He is having a clearout of his shop and just sent me a list of ZF parts he has for sale. All prices are negotiable.
1 ea. Used limited slip assy. Dash 2 $ 500.00
1 ea. Used limited slip assy. Dash 1 $ 700.00
1 ea. Used dash 1 main ZF case $1,200.00
2 ea. Used dash 2 side covers (set) $ 400.00
2 ea. Used dash 1 side covers with ears (set) $ 450.00
4 ea. M- 1 / GT 40 top cover vent each @ $ 15.00
2 ea. M-1 ratio speedometer pinion worm gear and output pin (sets) ea set $ 225.00
2 ea. Used ZF clutch throw out x-shaft and fork assembly – each $200.00
1 ea. M-1 / GT 40 side covers - set ( As New ) $ 600.00
2 ea. M-1 / GT 40 tail cover - steel ( AS NEW ) $ 350.00
1 ea. M-1 / GT 40 Racing tail cover with oil pump casting/ machining $ 550.00
3 ea. M-1 / GT 40 Racing tail cover pump cover ( magnesium ) ea. @ $ 220.00
2 ea. M-1 / GT 40 Racing tail cover pump impeller (steel) ea.@ $ 300.00
For more info, contact Les at [email protected]
He also does ZF work, so if you have one in need of GT40 conversion or general servicing/rebuilding, he'd be a good one to consider.
I am just the messenger....
