Brian,
The rules are set to change from the 1st April (very funny from VOSA). However, I got this from the draft on their site.
5.1 Roller Brake Test
A vehicle that incorporates an adjustment device
(eg pedal linkage balance bar) that adjusts the
front/rear braking ratio (longitudinal brake
distribution) must be tested in the “worst case”
condition, ie maximum rear axle braking.
NOTE: Devices that allow further adjustment, eg
lock nuts/adjustable stops, split pins, will not, in
isolation be considered as capable of preventing
further adjustment to a "worse" condition. (A roll
pin will be considered acceptable providing it
penetrates the full diameter of the component.)
The vehicle presenter may be required to adjust
any such device in order to comply with this
condition prior to the brake performance test.
If you don't have a copy of the manual ring them on 0870 6060440
Brett
