S-W 240A fuel pump
Dave Wood
Used pump taken off 60s era Model A hot rod, because of only hardline plumbing it is suspected that it created too much noise. This pump and a Holley Blue pump were on the car, but no longer plumbed or wired in. It has a small Mr. Gasket pump that now has some rubber hoses in the line and works well, it was also on the car with the hard lines. If you are a forum member I don't need to tell you what it is for, but if you are a spectator GT40s and S/C Cobras. It thumps when tested, I inspected the filter screen and all looks clean although I'd probably make sure. $300
Dave Wood
forgot to include the pic
