Sandy's GT Forte build
Hi I haven’t posted for quite a while not because I haven’t been working on my car it’s because I wanted a build thread so I am going to start posting my progress again but would appreciate if anyone wants to post negative statements about vendors of parts please could they start their own thread.
Sandy
Hi
Though I had better do an update
This is from July 2017 and I got the chassis rolling and trying the body work on.
I am very pleases with the Xmas present of the 8 stack throttle bodies I also received the dash board just before Xmas so will be concentrating on getting that positioned to allow for final position of steering wheel. and then the gear shifterThrottle bodies on engine.JPGNew cam sensor.jpg
Got a delivery on Monday the suspension parts arrived. So have been busy painting these and mocking up the parts to check the fit also the steering rack and the steering column are fitted also peddle box position has been determined. The front and rear uprights never came so will have to chase these up so i can confirm all is good with the moving parts. The Anti roll bar fixings I am not sure of the final positions for the drop links so will leave these until I get the uprights. I will continue with the panelling again now.
Sandy
Did you use a corsa c column?
NickD
Nice work Sandy. I’ve downed tools for a few months as I’m changing jobs / roles. Your work is looking good. Keep up the posts ! ;-)
Neville B
Hello Sandy, nice build! a question please, what do plan to do re painting the panel work, if you are not going to powder coat do you know what paint you will use and will you use a gun or can, thank you, Nobber
Hi sorry for the delay in reply but busy with house extension at the moment when not working so car is taking a back seat for a while but on the up side the car has a new home as knoking the old garage down for the extension.
The headers I made myself from 316 tube and bends.
As for painting the panel I haven’t given this a lot of thought as was originally thinking of leaving bare Aluminum but if this is a bad idea l would probably have to go for an etch primer and painted Finnish but think I would end up with an Aluminum silver colour if I did.
Sandy
Neville B
Sandy
Hi Sandy, I'm about 6 months into my gtforte build, can you tell me where you are as l'm in central Scotland. It would be great to pick your brains a bit.
Cheers tony
Well far too long from any progress but house renovations now completed spent the last few days making fuel filler caps as couldn’t bring myself to part with the amount of money they cost for the two of them. So bought some aluminium billet off cuts and a few days on the lathe and cutting and filling and very pleased with the results.
