I am going to fabricate my upper & lower control arms and I am trying to figure out where I can go to determine what diameter and wall steel tubing I need. I am pretty set on using 1" diameter DOM for all of arms and pushrods, but I just don't know where to begin figuring wall thickness.
The pushrod bracket will be welded directly to the vertical tube that contains the tie rod on the lower control arm. The anti-roll bars will attach to the inboard springs, so there will not be bending forces on the a arms other than from the forces from the wheels.
These a arms will carry the C5 Corvette uprights.
I am not looking for featherweight arms that will not be reliable over an extended period of time, but I also don't want to carry unnecessary weight. Obviously these are CRITICAL components and a failure could be catastrophic so slightly overbuilding will be in order.
I am figuring the following variables will come into play:
Total vehicle weight
Max Cornering G, Braking G & Accel G
Length and Layout of A Arms ( Rears will be right triangles, fronts, isosceles triangles)
HP / TQ
If anyone could provide some input it would be great.
Derek
HP / TQ
Derek
