Spherical rod end
Hi All,
I'm hoping someone can help with this.
Can any one tell me where I can source, both RH and LH 11/16" Spherical male rod end ? :huh:
Any help would be appreciated as I need a solution to replace a tie rod on the upper front arms that uses a 11/16" tie rod, however the tie rod supplied are not at 90 degrees into the stub axle causing the front suspension to bind on the tie rod not at full shock droop.:sad:
So I figure that replacing it with a rod end would solve the issue as I can't find a 11/16" Tie Rod that is at 90 degrees, the only ones I've found are all about 80-85 degrees.
Thanks in advance....
John
John, Im reading between the lines here, I think the end you might need is the steering tie rod end from a ford transit- circa 1965-- I assume from your description your using it as a --top outer ball joint on the top w/bone--- quite common amongst kit cars such as locost etc. Early ones IIRC were 11/16 thread, later are metric 18mm. Hope that helps.
