Lots of info needed to design a chassis, wow!!
Fran Hall RCR Jan 27, 2008 #2 Looks similar to Chris's Active Power chassis..... If you use your current C5 donor parts it will not be too bad but there will be compromises...but it will be a fun exercise in patience....enjoy Last edited: Jan 27, 2008
P PaulGT40 Jan 27, 2008 #3 I don't suppose there are a lot of different ways to lay out using corvette suspension. gt40fran said: Looks similar to Chris's Active Power chassis..... Click to expand...
Fran Hall RCR Jan 27, 2008 #4 Your vertical chassis uprights have the same arch to them where your crossmember will mount also. Attachments active power chassis.jpg 47.4 KB · Views: 534 Last edited: Jan 27, 2008
P PaulGT40 Jan 27, 2008 #5 Are you suggesting this is a problem or ? gt40fran said: Your vertical chassis uprights have the same arch to them where your crossmember will mount also. Click to expand...
Fran Hall RCR Jan 27, 2008 #6 No.....not at all...... Chris is a super guy and may well be willing to help you out as you are using similar componentry to his chassis...or even sell you plans etc etc
