Mike Pass
Steel flywheel for Ford Windsor. New. NEUTRAL balance. From Southern GT. Drilled and tapped for SGT AP clutch. Weight 8.9 Kg . Diameter across ring gear teeth - 313mm £200
Procomp billet distributor and matching ignition coil. New PC8023 distributor and PC2041D-RD ignition coil for Ford Windsor. Two sets available £100 each set.
Moroso new chrome 14” drop base circular air cleaner for Holley etc. with filter element. £25
New Taylor 8mm Pro Series ignition wire set for V8. Black. £30
All parts are located in Oldham Greater Manchester UK. Collection or carriage is down to you to arrange.
