Thank you Paul, Graham & Mike ! i will disassemble mine and look at the references to understand what it is and what is wrong...
( The steering angle of the car is absolutely zero..)
Check that the rack input shaft is turning when you turn the steering wheel. If the input shaft is turning the problem is in the rack. If the rack input shaft is not turning the problem is the steering column.
