Mitch Krause
I guess the throttle is on the engine, so this is the right place for this post I hope. The first picture is taken from the top of the engine and shows the two golden colored arms, one connected to the webers and the other connected to the throttle cable (9 foot Lokar). If I remove the connection from the throttle cable and then use a loop of wire in the same holes that the throttle cable connects to and pull at the same angle as the throttle cable pulls (using a fish scale), the pull peaks at about 8 pounds (right at the start) and is a pretty steady 5 pounds throughout the pull to wide open throttle.
If I have the throttle cable disconnected and laying on top of the engine and move the pedal to wide open throttle, then use the fish scale, it takes a pretty steady 2 to 3 pounds to pull the pedal back to the closed throttle position.
If I have everything hooked up and put my fish scale at the top of the pedal, it takes about 14 pounds peak force to get it moving and about 12 pounds pretty steady pressure throughout to move to wide open throttle.
I guess maybe this makes some sense for the pull since 8 pounds (weber alone peak) and 2-3 pounds (cable alone) is pretty close to that (14 pounds versus 10 or 11), maybe some additional force with things all connected and slightly different aligns.
However the pedal does NOT return to the closed position once it is at WOT. If you hook the fish scale around the arm where the throttle cable connects, it takes about 4 pounds to "help" pull it back to closed throttle. When the carbs at at WOT, the backwards pull is about 5 pounds as you let it run back to closed throttle.
Regardless, the 14 pounds at the pedal, make it very stiff. Of course both the pedal and the little arm where the throttle cable connects actually travel in a slightly circular arc as they go through their range of motion, which means you can never have perfect alignment to the opening of the cable in the throttle sheath. Perhaps I could have slightly better to eliminate a couple of the pounds.
Picture Two shows the routing of the cable from the engine to the left hand side of the drivers seat. The bends are pretty gradual, at least I think they are. Red lines underline the throttle cable where it is hard to see behind the driver and running through the bulkhead to start towards the front.
Picture three shows the cable from the side of the driver into the pedal, again I think the bends are as gradual as they can be.
I did have a "test" spring I put on the carb end to help pull things back. That made the pedal push peak at about 30 pounds, but it would (rather slowly) return to closed throttle.
So now the questions. Where to start to take some of the hard pull away? Is the 8 pounds on the webers normal? Are they stiffer than they should be (no gas in them, maybe not lubricated), will they ease in real use? What should the expected pedal force be in pounds (anyone ever measured that)?
