Troy I am new to the forum but have owned my SL-C since 2009. I recommend that before you mount anything that you drop in the engine and gearbox, then start to locate all the items you are going to put into your car, surge tank, oil coolers electricals oil tank, all the main items. At that point you mark all the items for where you will locate them from there you figure the plumbing for each item of where you will try to run them. Then you pull all the stuff back out of the car and start to mount all items, once completed route the plumbing since a lot of the plumbing will get in the way of the rest of the plumbing, once this is completed place the engine back in the car and hook up along with the gearbox. Then you can fine tune the plumbing. With the engine out of the car it is easier to get to everything to mount and plumb. Keep in mind the plumbing needs to be routed as far from the exhaust as possible. I also wrapped all the oil lines and shift cables in insulation from Summit to include the cloth type wrap held in place with tie wire then the silver tube insulation over that. I have been going through the problems with the fuel pump and surge tank also. I burned up a transfer pump, 2 HP pumps. I went to Aeromotive tech guru and sent them a complete diagram of the fuel system along with pictures. We found out the HP was cavitating even though it had the surge tank. We replumbed the fuel system as follows
fuel tank to 40 filter to transfer pump to surge tank to HP to 10 filter to engine to regulator to surge tank. We ran all #10 lines except from regulator to surge tank was a number 8 and from surge tank to fuel tank #8. The cavitation was caused from the line from the surge tank to the HP was too long. We rerouted the line so that all lines except the line from the HP to the engine are less than 1 ft long.I hope some of this info will help.
Bob D
