Charlie Farley
Found this info and thought to share it.
I cant vouch for its reliability, but thought it interesting enough to post here.
Any thoughts on its validity?
Tip 1: You are *MUCH* more likely to get 'let off' if you are pulled over for speeding
by a NORMAL Police officer (black hat, black uniform) than by a TRAFFIC officer
(white hat, green overcoat).
It's a traffic officer's JOB to catch you, where as it can be an inconvenience
for a normal Police officer to actually go through with prosecuting you. Also, it
is highly unlikely that a normal officer (as apposed to a Traffic officer) will
be able to make a case against you if you are armed with the information in this
course.
If a Traffic officer has evidence against you (note: not necessarily ENOUGH
evidence for a conviction), then they will attempt to fine / prosecute you. The
situation with an ordinary Police officer is less clear cut. Often, if you are
particularly courteous and try to strike up a friendly banter with a Normal
officer, they will give you a 'slap on the wrist' and send you on your way.
It is extremely important to remember to distinguish between the two types so
that you are able to plan your attack. If you are pulled by a Traffic officer,
then do not concede anything otherwise this evidence will be recorded and damning.
Tip 2: All speed pacing police cars have to have their Speedo's measured and certified.
Typically, ONLY traffic police cars are calibrated, and the Speedo will have
increments of 1 mph. If you are stopped by a NON-traffic officer, and told that
he/she followed you, and you were speeding, simply ask as a matter of course when
his Speedo was last calibrated. *It is likely he will let you go* when you ask
this question since normal police (Beat) cars do not have certified Speedo's;
theirs is the same as yours and mine!
Tip 3ON'T BE BULLIED IN TO SIGNING THE DECLARATION
Not enough people who are 'caught' for speeding fight it in court, they simply accept it, get the points and pay the fine. If more than 10% fought the ticket, the judicial system dealing with this would be overwhelmed and brought down on its knees.
If in doubt, fight it! The worst thing that can happen is that you will be convicted of the original offence. You CAN get a heftier fine and more points in court, but unless you were doing silly speeds, it's very unlikely.
The first point to make is if you receive a ticket in the post, *DO NOT SIGN THE DECLARATION* because this is viewed as an admission of guilt. Rather, send the forms back with a signed covering letter. You should explain that none of the options presented on the form apply to you and you are therefore unable to sign it.
An excuse which has worked for many is to say that you have no idea who was driving the car - you are just sure it wasn't you because <insert reason>. It could have been any one of several friends or family members. Request the police send a photograph of the driver so that you can identify them to assist them with their enquiry.
They will most likely send a picture of the car from behind, unless you were caught on a Truvelo camera (a great way to protect against Truvelo's is by using PhotoBlocker spray, which doesn't allow static cameras to photograph your number plate! See this link www.beatthespeedtrap.co.uk/photoblocker.html).
The Police will demand that you sign the form, but do not back down - politely explain why you can not sign the form (because none of the options available to sign apply to you). They will continue to demand that you sign, but legally, you have no obligation to do so - so don't!
Try to avoid being too sarcastic or pompous in your communications in case it does go to court (please be aware that it is likely to actually go to court but you are extremely likely to win the case). You will want the court to recognise that you are sincere and reasonable. They will throw the case out if the Police can not PROVE you were driving.
course.
