Russ,
No clue what the KPI is. Neither SAI or included angle were provided on the printout from the alignment. Although, someone who is intimately familiar with '85-'87 'Vette front uprights might be able to deduce what it is based on the camber/caster values.
I agree with your and Chris' speculation that the arms were probably designed for ease of construction, but with John Donnelley's whereabouts being an unknown, you are also right in saying, "who's to say?" I am not a racing suspension expert and I don't even own software for analysing suspesnsions, so I am in no position to redesign the Sabre front suspension. I am just another replica owner trying to make the best of the situation he is confronted with in a car with no visible means of support and who put more faith in a constructor than, in hindsight, he was deserving of.
Lynn
Lynn,
You almost sound as though you are throwing your hands up in despair. That being the case you are selling yourself short! You have helped me and many others on this forum with your technical expertise in many areas.
You have a problem that is essentially simple to overcome but may be best resolved with new top arms. With a new top arm you will want to design it so that you optimise your suspension. This means taking into account the inherent KPI of your upright. Caster, camber and toe settings that are determined for a saloon car with a big hunk of cast iron hung high over the front suspension may not be the optimum for your Sabre. Therefore given the fixed design parameters of your setup i.e. basically retaining the the lower arm and the upright, the steering arm and the inboard pickup points. You redesign the top arm to achieve the best compromise for your application.
The KPI of your upright is a figure that GM have decided on for whatever reason. You cannot change that without changing the upright. Basically KPI is the angle that a line through the middle of the top and bottom balls makes with the vertical when viewed head on. It is generally in the region of 3* to 10* positive It is easily measured.
Consider the RHS. Say you have 10* KPI. If you were running zero caster and zero camber, if you turned the wheel to the left so that it was at 90* to the longitudinal axis of the car then at that point the wheel would have swung to 10* negative camber. If instead you turned that wheel 90* to the right at that point it would achieve 10* positive caster.
If you consider a left hand turn given those parameters then the right hand wheel goes negative and the left hand wheel goes positive i.e. both lean into the corner, this is desirable in small quantities to compensate for body roll and tyre characteristics. Of course you never achieve 90* lock so the actual figures at full lock are less. But non the less the camber change on lock is excessive. This can be compensated for by introducing caster.
If we were to introduce 10* caster with the same scenario we would now have zero camber at 90* LH lock. Much better. But look at 90* RH lock this setting becomes cumulative not compensatory thus you have 20* camber at 90* LH lock.
Remember that the inside wheel which goes excessively positive on lock is not as heavily loaded as the outside wheel (except under parking conditions) so is not quite so important. All you have to do is set sufficient caster into your new top arm to give a compromise that
you are happy with.
You are effectively stuck with the KPI and Ackermann so you must do the best that you can with the caster.
This approach is putting the cart before the horse IMHO but that's what you're going to have to do.
If you had a clean sheet of paper you would determine the caster you wanted to run for self centering, and the KPI and everything else would follow on from that. Frank will disagree. Suspension theory is like economic theory, nobody's right and nobody's wrong!
If designing from scratch you would have a totally different approach, but you are trying to make the best of existing parameters.
Frank runs huge caster because he is running huge KPI and you know what that does to the inside wheel. Personally, the compromises that Frank has made designing from scratch are not the ones that I would make, however his suspensions appear to work and be well received.
So as noted before it’s a matter of what works for you. Whatever you do has got to be better than what you’ve got there. And you can do it!
Hope that is of some assistance.
Cheers,
