Wilwood Mechanical Handbrake Spot Parking Brake Caliper - Pair
Pair of Wildwood cable operated handbrake callipers, well used & well worn. Fitted with spacers to suit 28mm thick discs and extended pull levers. In honesty, these callipers do not work particularly well, but when correctly adjusted & setup they worked well enough to pass an MOT, once! May be useful to someone building on a budget. They will need refurbishing.
£50 for the pair plus postage
Located in North Devon, UK
