Thread: Tach
Old 04-19-05, 05:41 PM   #15 (permalink)
p thompson's Avatar
p thompson
Administrator
GT40: None
Re: Tach
[ QUOTE ]
Can you configure output one from the ECU to drive tach signal?
[/ QUOTE ]
Dave - from first menu - select:
INPUT/OUTPUT FUNCTIONS
then
AUX OUTPUT 1
then
SET VALUE to '4'
This corresponds to 'Tacho Signal'
see screen shots below -
ps - this is the setting we use for M48Pro with 8-coil ignition / ignition expander as fitted to Roy Smarts Mk1 GTD. Hope it helps.
p thompson is offline   Reply With Quote
