Jonathans RCR 40 Build
Doors
I have finally gotten back to work on my car. Fran got the hinges to me a couple of weeks ago and I have finished mounting and fitting one door. The other door is mounted but not fitted yet. The gaps are pretty good. It took quite a bit of patience to get the doors properly trimmed but I am happy with the results. Here are a couple of shots:
Stiker Plate
I had to shim the door striker out 2 inches so I built the shim to allow adjustment. The shim has a vertical slot and the firewall has a horizontal slot for full adjustment. Here are some shots of the striker:
Nice work on those and it looks like some progress is being made. I'm waiting for the 1/2 shafts too, but I know those have been delayed and will be along shortly. They don't hold anything up though. Is your 016 stock?
Dutton
Nice touch on the striker alignment, Jonathan.
If you don't mind, set aside those notes you pass along to Bill... your coaching will be darn valuable in my garage, too!
T.
I have not posted for a while but I have been hard at work. I have most of the bodywork done. I should have the car in primer within a week. Here are some photos of my progress on the bodywork.
Jonathan, it was nice meeting you last week at the Dragon run. The car looks good and I am sure it will be one of the nicer ones around given how your cobra turned out. chuck smith
WOW!! Great progress. I feel like I'm moving at a snail's pace compared to you and Ron!! I better get my tail moving!!
I decided to modify the rear deck so that the plate would sit flush. Fran supplies a cover cut from plate but the deck is taken from an original car so it is set up for sheet metal. I cut out the lip and reglassed it to get a deeper recess. Here is a shot of the progress:
I also did the cutouts and fabricated a mount for the fog lights. Here are some pictures (the front clip is upside down in these):
Doug S.
jonathans said:
All the big ticket stuff is included in the deluxe kit except engine, trans, and flywheel. There are a lot of little things to buy though. It will probably be a few months before I have a full list together.
When you do complete this list of "little things to buy", would you mind posting it on the forum? The RCR is at the top of my short list and I can afford to start purchasing some of those things that are not included in the deluxe roller kit now. IMHO, one of the biggest challenges is sourcing parts, so I will purchase the most complete kit available when that day comes, but I don't have the knowledge or experience in this specialized endeavor to know where to get many things. A head start could be very valuable.
Thanks, Jonathan.
Doug
I finished priming the car. Here are some shots:
I started painting today. I put down the silver for the stripes. Here are a couple of photos:
Dutton
It's coming along real well, Jonathan... and especially rewarding to see a fellow RF Mate getting closer to the dream!
When you have a few extra minutes (and you're not in the garage), I'd sure be interested in your take on body prep for your RCR, things to look out for, any special tools you used, etc.
Great progress, man. Can't wait to see the next installment!
Best,
T.
As far as body prep the panel alignment on this car was incredible. Misalignments were so small that almost no filler was needed for panel alignment. There are a few places where the body gets a little wavy. If you go to my web pages you can see shots of the car with body filler on it. That is a good guide to where my body had waves. The toughest part was getting the back of the spider to match the door and rear clip. This part seems to have gotten a twist to it after it is pulled from the mold.
As far as special tools nothing fancy is required, its just lots of sanding. I only use DA sanders and air files early on. Once I have the gel coat scuffed I go to long boards. I only use the power tools on the primer if I have a lot of orange peel to knock down. The AFS boards are really nice when you are blocking out the car.
