| Re: wiring loom for reference having spoken to jerry in uk there is a need to make some un mentioned alterations to the multi pin plug by the permenant feed in order to get the fans and fuel pumps working ,THEY ARE
white --- speedo connection
pink ----- tacho feed
red green ----ignition live (connect to fuel pump,electronic ignition, and carb
fuel cut off)
green/black---- fuel pump connect to ignition live
blue/white------Electric fans connect to earth(may relate to an inline
thermostat fan switch)
blue orange----- spare
red white ------spare
black------- obvious earth
the wiring loom is made for an ecu unit but hopefully the above will allow my carb version to work. Currently seems ok except when switch from the right to left tank the 15 amp fuse blows ,probably as the return valve I used is wired in correctly as there was no wire fo it in the loom and I boldly connected it via the lifter pump on the rt tank
Why is it when you need to get under the car to check the problem the trolley jack decides to blow its mortal seal! oh well at least theres 7 shopping days left |
