| Re: S2000 start switch S 2000 is the only Honda I know uses a start switch separate from the key. If you use it you'll need to go through a relay as it's a very low amp switch. I have one of these and a connector, I might have an extra connector. I'm going to sell it because I don't want another relay, already have 10 of them.
good luck at the junkyard, but there was another recall for something else that had the same connector, so there were some of these laying around the shop but it's been a couple years gone by.
I also have the wiring diagram somewhere, when I get time next couple days I'll dig it up, most likely by next monday. But the description Bill found is most likely correct, you can check it with an ohm meter. |
