| Re: gtd pedal box Put in one of the floor mounted Tilton setups. You will have to weld in a plate - not easy. You can get a suitable plate ready drilled from Mick Sollis at Southern GT. The basic problem with any top hung setup is that you can not get a good ratio between the foot and master cylinder. With a floor mount setup the pedal ratio is much better - you will need this extra mechanical advantage if you want to do away with the servos. A very cheap floor mount can be found on ebay by typing in pedal box - about £180 for the basic bias box.
Mike |
