Thread: G50/04
Old 01-26-08, 07:03 AM   #6 (permalink)
EGLITOM's Avatar
EGLITOM
3 Tenths
Germany
GT40: RCR 40
Rep Power: 6 EGLITOM is a splendid one to behold
Re: G50/04
Originally Posted by Russ Noble View Post
This is an oft repeated urban myth. Everything that I have researched indicates that internally the G50/52 is the same as a G50/50, only difference being the end housing and mount.
WRT your G50/04. I think sideshifts are available from CMS who advertise on here.
Hallo Russ , interesting to hear.
I just copied it in because i wanted to show that the G50/04 has the same long first gear ratio, but than more closer and and more even staged 2nd to 5th gear with the final drive ratio of the G50/03. So for me in terms of ratios it is just perfect. Frankly all this talking about gearing for 200 mph is just not realistic, this cars getting so much air drag at higher speeds, that you would need massive power and very long straight to even reach 190 mph so a gearing for 185 - 190 should be fine in my opinion.
TOM
EGLITOM is offline   Reply With Quote
