Old 05-01-08, 07:49 AM   #1 (permalink)
EGLITOM's Avatar
EGLITOM
2 Tenths
GT40: RCR 40
Rep Power: 4 EGLITOM is a splendid one to behold
Passenger compartment venting
Hallo
I think about a smart solution to vent the passenger compartment, in order to release the pressure build up by fresh air supply by connected fresh air ducts.
I donīt want to build anything into the roof. I also donīt want to drive around all the time with open side windows.
As my plan is to get the car watertight, natural venting will be limited.
The current idea is to use the service/access opening of the RCR 40s which are behind the seat to service and acces the radius rod mounts.
The idea is to use a venting valve( they usually provide a backflow prevention) from an passenger car , mount it in this access panel and thats it. This way overpressure should be able to vent out and if there is more pressure on the other side , the ventvalve will lock it out.
There should be no issue with water and odors.
Would be interessed in your opinion and ideas.
TOM
RCR 40 ; LEVY RACING 331; G50/05; gulfwide
EGLITOM is online now   Reply With Quote
