Goodyear vs. Avon
Hello,
I know this subject has discussed several times, but I have a specific question. I'm putting 15" wheels on my SPF Gulf GT40. I really like the large lettering on the Goodyear and Avon tires. I think it gives the car an old vintage racer look.
Question is... which tire is better for 70% street and 30% track? Which one would pick up less rocks on the street? Attached is a photo of the Goodyears and Avon's I'm thinking of getting.
~ Randy.
Hi Randy, possible to be precise about exactly which Avon or Goodear you're interested in? I'm guessing the Avons you're thinking about are the CR6ZZ's based upon the tread pattern and likely sizing.
I ran the GY Billboard tires from Roger Kraus on my cobra and they pick up rocks like crazy. I had aluminum spats on the car and they got pretty beat up.
[/IMG]
And that is a KEY POINT I have been trying to get people to understand for years now... You run racetires on the street - kiss your nice paintjob goodbye.. You also pick up a lot of star cracks in the paint job above the tires.
The answer is 2 sets of wheels/tires. You can get a used set of either Goodyears or Avons free by looking behind the tire trailer at any vintage race meet. The used tires have plenty of tread left on them (if you could call it tread) but they are no longer sticky
enough to race on. You could use these tires for display or limited street use but they do not drive so good as the radials you are used to. You can get good used tires for track use if you are a beginner. If you are racing, you want new tires. If you are looking for a tire that does not pick up rocks and is good for the street or track and has big letters, it does not exist really. What makes it good for one use is the same thing that makesw it bad for another use.
The Dunlop race tires drive the best on the street and perhaps you could stencil Goodyear on them.
See the tirelist onby,
It definitely depends on what you mean with " works on the track". I have heard good things about the AVON CR6zz. The Pirellis would also do a decent job. But thats it IMHO.
Judging by your AVATAR you should have a lot of 15" experience :thumbsup:
TOM
does anyone know of a good surplier of the vintage race tyres in the uk??? i love the white lettering on the side for that vintage race car look
cheers
james
thats a good chart....
whats the widest tire we can fit on the rear of the stock SPF rim?
I assume the rear rim width is 10" . Is this correct.
If you check the chart you could check for the tires which are in "measuring rim" size up to 11", because this rim are usually representing the optimal rime size from which you can diviade + - 1 - 1,5" .
I filtered the chart accordingly and came up with this selection.
<TABLE style="WIDTH: 958pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=1274 border=0 x:str><COLGROUP><COL style="WIDTH: 77pt; mso-width-source: userset; mso-width-alt: 3766" width=103><COL style="WIDTH: 109pt; mso-width-source: userset; mso-width-alt: 5302" width=145><COL style="WIDTH: 101pt; mso-width-source: userset; mso-width-alt: 4937" width=135><COL style="WIDTH: 60pt" width=80><COL style="DISPLAY: none; mso-width-source: userset; mso-width-alt: 0" span=2 width=0><COL style="WIDTH: 68pt; mso-width-source: userset; mso-width-alt: 3291" width=90><COL style="WIDTH: 60pt" width=80><COL style="WIDTH: 91pt; mso-width-source: userset; mso-width-alt: 4425" width=121><COL style="WIDTH: 66pt; mso-width-source: userset; mso-width-alt: 3218" width=88><COL style="WIDTH: 68pt; mso-width-source: userset; mso-width-alt: 3291" width=90><COL style="WIDTH: 71pt; mso-width-source: userset; mso-width-alt: 3437" span=3 width=94><COL style="WIDTH: 45pt; mso-width-source: userset; mso-width-alt: 2194" width=60><TBODY><TR style="HEIGHT: 13.5pt" height=18><TD class=xl36 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; WIDTH: 77pt; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.5pt; BACKGROUND-COLOR: transparent" width=103 height=18>Brand</TD><TD class=xl37 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; WIDTH: 109pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=145>Type</TD><TD class=xl38 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: #ece9d8; WIDTH: 101pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=135>OFFICIAL SIZE</TD><TD class=xl39 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; WIDTH: 60pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=80>Dia wheel</TD><TD class=xl38 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=0>Width</TD><TD class=xl39 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=0>Ratio</TD><TD class=xl39 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext; WIDTH: 68pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=90>Tire Height</TD><TD class=xl39 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext; WIDTH: 60pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=80>TOTAL DIA</TD><TD class=xl38 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: #ece9d8; WIDTH: 91pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=121>TOTAL DIA in mm</TD><TD class=xl39 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; WIDTH: 66pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=88>Threadwith</TD><TD class=xl38 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: #ece9d8; WIDTH: 68pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=90>Sectionwidth</TD><TD class=xl39 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; WIDTH: 71pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=94>Measuring Rim</TD><TD class=xl38 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: #ece9d8; WIDTH: 71pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=94>Max RIM</TD><TD class=xl39 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; WIDTH: 71pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=94>Speedrating</TD><TD class=xl39 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext; WIDTH: 45pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=60>RADIAL</TD></TR><TR style="DISPLAY: none" height=0><TD class=xl40 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl41 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl42 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl43 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl42 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl43 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl43 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl43 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl44 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl43 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl42 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl43 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl42 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl43 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl43 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"> </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>MICHELIN</TD><TD class=xl33 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">TB5R</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">285/40-15</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>15</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>285</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>40</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="4.5078740157480315" x:fmla="=+(H3-D3)/2">4,5</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="24.015748031496063" x:fmla="=+I3/25.4">24,0</TD><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="610">610,0</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="11.456692913385828" x:fmla="=291/25.4">11,5</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>10</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>12</TD><TD class=xl45 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">ZR</TD><TD class=xl46 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"> </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>MICHELIN</TD><TD class=xl33 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">TB5R</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">270/45-15</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>15</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>270</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>45</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="4.6850393700787407" x:fmla="=+(H4-D4)/2">4,7</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="24.370078740157481" x:fmla="=+I4/25.4">24,4</TD><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="619">619,0</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="10.94488188976378" x:fmla="=278/25.4">10,9</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>9</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="10.5">10,5</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">ZR</TD><TD class=xl46 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"> </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>HOOSIER</TD><TD class=xl33 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">R6</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">275/50-15</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>15</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>275</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>50</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="5.25" x:fmla="=+(H5-D5)/2">5,3</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="25.5">25,5</TD><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="647.7" x:fmla="=+H5*25.4">647,7</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="10">10,0</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="10.8">10,8</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>8</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="9.5">9,5</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">RACETIRE</TD><TD class=xl46 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">x</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>GOODYEAR</TD><TD class=xl33 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">BLUE STREAK</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">26,5 x10.0-15 ( cobra)</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>15</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"> </TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="5.75" x:fmla="=+(H6-D6)/2">5,8</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="26.5">26,5</TD><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="673.1" x:fmla="=+H6*25.4">673,1</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="10.2">10,2</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="12.9">12,9</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>10</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="10.5">10,5</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">RACETIRE</TD><TD class=xl46 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"> </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>AVON</TD><TD class=xl33 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">Cr6ZZ</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">295/50-15</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>15</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>295</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>50</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="5.8" x:fmla="=+(H7-D7)/2">5,8</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="26.6">26,6</TD><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="675.64" x:fmla="=+H7*25.4">675,6</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="9.9">9,9</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="12.2">12,2</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>9</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>10</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">VR</TD><TD class=xl46 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"> </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>HANKOOK</TD><TD class=xl33 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">RH 06</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">295/50-15</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>15</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>295</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>50</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="5.8" x:fmla="=+(H8-D8)/2">5,8</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="26.6">26,6</TD><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="675.64" x:fmla="=+H8*25.4">675,6</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="9.8">9,8</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="12.4">12,4</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="9.5">9,5</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">VR</TD><TD class=xl46 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">x</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>GOODYEAR</TD><TD class=xl33 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">BLUE STREAK</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">8,00-15(G7)</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>15</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"> </TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="5.9" x:fmla="=+(H9-D9)/2">5,9</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="26.8">26,8</TD><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="680.72" x:fmla="=+H9*25.4">680,7</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="10.3">10,3</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="13.2">13,2</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>10</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="11.5">11,5</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">RACETIRE</TD><TD class=xl46 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"> </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>NITTO</TD><TD class=xl33 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">NT 555 R</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">325/50-R15</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>15</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"> </TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="6.45" x:fmla="=+(H10-D10)/2">6,5</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="27.9">27,9</TD><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="708.66" x:fmla="=+H10*25.4">708,7</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">??</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="13.1">13,1</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">??</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num="11.5">11,5</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">VR</TD><TD class=xl46 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"> </TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD class=xl27 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 13.5pt; BACKGROUND-COLOR: transparent" height=18>BF GOODRICH</TD><TD class=xl34 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent">G Force Drag radial T/A</TD><TD class=xl28 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent">325/50-R15</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent" x:num>15</TD><TD class=xl28 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"> </TD><TD class=xl31 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"> </TD><TD class=xl35 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent" x:num="6.45" x:fmla="=+(H11-D11)/2">6,5</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent" x:num="27.9">27,9</TD><TD class=xl29 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent" x:num="708.66" x:fmla="=+H11*25.4">708,7</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"> </TD><TD class=xl28 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent" x:num>13</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent" x:num>10</TD><TD class=xl28 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent" x:num>12</TD><TD class=xl31 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent">??</TD><TD class=xl47 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent">x</TD></TR></TBODY></TABLE>
to be sure go for the rim recos of the tire specification.
Also a thing to check is clearance through the whole suspension travel. Especially the wide and big diameter tires like the last three in this list could create some issues on this topic.
TOM
I know this is an old thread but I've been looking for some tyres for my Tornado for about the same amount of usage 70% road, 30% track.
I've concluded that I am going to try and get 2 sets of wheels/tyres. For road I am going to get some Avon CR6ZZ but what would be recommended for track use?
Has anyone used the Michelin TB5R's they look like they could be very handy for track work as they are semi slicks?
Trev
