I am creating a scratch built 906 of sorts. Starting with a scanned scale blueprint vector files are being created for each piece of tubing. I am looking to recreate as accurately as possible the space frame as the starting point. Does any one have any dimensions for tubing diameter and thickness for the space frame.
With the 3d space frame completed the fun begins. Examining the Historic plan set for weakness when I introduce a 55 kilo motor producing 240 Nm of torque with an RPM range of 2000 to 8000, maxing out at 11000 rpm.
High density energy storage and ultra caps will be part of the mix.
If you have a 906 body mold set I would like to commission something special. I also have a contact for custom DOT compliant windshield manufacturer interested in filling a specialty niche. this is an inspiring site. I have the cad cam software to run a five axis mill like the one creating molds seen in another thread. I do not want to reinvent the wheel here the designers that built this vehicle using slide rules and adding machines are giants. I would like to build on their work.:idea:
