| Notices | Hi member,
Enjoy the forum!
Why not start with your first post today and become an active part of GT40s.com now! And, if you find you enjoy GT40s.com think about becoming a Forum Supporter. | | GT40 Build Logs For build threads and build diaries only. |
03-21-05, 08:44 AM
#121 (permalink)
| | John W 6 Tenths
Join Date: Jan 2005 Location: Surrey, England GT40: lots of bits but not bolted together yet...
Rep Power: 11  | Re: PW Tornado Build pics you could always climb in through the window in dukes of hazard style [img]/ubbthreads/images/graemlins/wink.gif[/img] |
03-21-05, 09:17 AM
#122 (permalink)
Join Date: Nov 2003 Location: Heathrow, London, UK GT40: Dax 40 Mk1 (Rover3.9EFi)
Rep Power: 18  | Re: PW Tornado Build pics Paul
Welcome to the curse of the narrow garage!
Ian |
03-21-05, 04:03 PM
#123 (permalink)
| | PDub 6 Tenths
Rep Power: 12  | Re: PW Tornado Build pics OK so I have done the Dukes of hazard thing - let me tell you it is a hazard in these cars. Dave morton suggested I step between the door and the A pillar but my garage roof isn't very high either so you have to watch yer bonce on the roof ! The easiest way at the moment is to crouch under the roof of the door and then do a 180 to sit on the cill and swing your legs in.
I started extending my garage today - and a re-roof higher. |
03-22-05, 05:18 AM
#124 (permalink)
| | delaneyp Peter D
Join Date: Sep 2001 Location: Sydney, Australia GT40: DRB #27
Rep Power: 21  | Re: PW Tornado Build pics Paul, sorting the garage out is a necessary step, but the big, bad world awaits !!
My back has been playing up for a while, so gymnastics are out for me. Last w/e I went out to the local hardware store & parked well away from everyone & did my shopping - when I came out, lo & behold - a dirty big 4WD on my RHS & not a chance in hell of me getting into the car !
I spent half an hour leaning on the car & fielding questions from on-lookers until the 4WD owner finally turned up ! Not so bad, as there is always someone to talk to while you wait !!
Have fun !
Kind Regards,
Peter D. |
04-26-05, 12:58 PM
#125 (permalink)
| | PDub 6 Tenths
Rep Power: 12  | Re: PW Tornado Build pics Rebuilt the garage - a bit more space ........ |
04-29-05, 03:24 PM
#126 (permalink)
| | kenshiro8 I Have No Life
Join Date: Jul 2004 Location: Milano,Italy GT40: Fujimi 1/24
Rep Power: 28  | Re: PW Tornado Build pics LOL....our Fiat 500 masterpiece down there.
U really love GREAT cars. [img]/ubbthreads/images/graemlins/grin.gif[/img]
Great great great work,go on go on [img]/ubbthreads/images/graemlins/blush.gif[/img]
Paul-italy |
06-11-05, 03:03 PM
#127 (permalink)
| | PDub 6 Tenths
Rep Power: 12  | Re: PW Tornado Build pics Been fitting/modifying the wiring loom so not many pics to post - most of its done now so onto the fuel system. Fuel pumps / filters / cutoff valves all fitted and onto the tanks. |
06-11-05, 03:04 PM
#128 (permalink)
| | PDub 6 Tenths
Rep Power: 12  | Re: PW Tornado Build pics Fitted - there is foam between the tank and the chassis/brackets but this pic makes it look like there isn't any. |
06-26-05, 03:25 PM
#129 (permalink)
| | PDub 6 Tenths
Rep Power: 12  | Re: PW Tornado Build pics Change of plan on the lights - moved the indicator from the outside (gulf position) to inside the lower recess and made up some tinted lenses.
Now in the dash fitting / wiring mode. |
06-30-05, 11:09 AM
#130 (permalink)
How do you do for minimum height from ground (SVA) for that indicator?
Or are you going to fit another for the SVA?
Ian |
07-02-05, 03:01 PM
#131 (permalink)
| | PDub 6 Tenths
Rep Power: 12  | Re: PW Tornado Build pics The lower recess will be blocked off for SVA (Tape over the light cover) and another indicator mounted in the headlight recess temporarily. I don't think there is any way of mounting an indicator in the lower recess that will pass UK SVA. I'm about to mount the side repeater above the body catches that I have just mounted : - |
07-03-05, 06:30 AM
#132 (permalink)
Rep Power: 57  | Re: PW Tornado Build pics Paul, it looks nice! I have just one suggestion though on your tank mounting - you might want to take the time to weld some "ears" about 1.5" wide and 6" long on the outside of the tank parallel to the front and rear down tubes that are in front of and at the rear of the tank. These ears would overlap on the downtubes. Then, you could drill holes in the ears, holes in the down tubes and secure the tank firmly using bolts and do away with the three folded straps that hold it in place now. It would be a little more secure and eliminate any virbration that might occur with the compressed strap method.
It might already have something like that though.
R |
07-03-05, 08:04 AM
#133 (permalink)
| | PDub 6 Tenths
Rep Power: 12  | Re: PW Tornado Build pics Ron, I considered this when i was designing the tanks but my welder man thought that any sort of "ears" would create a stress point on the tank. The straps I have used have foam (compressed) all the way around the tank so it is held firmly in place - they are very tight on the tank. It's a bit hard to see from the pic I posted. |
07-06-05, 11:26 AM
#134 (permalink)
| | PDub 6 Tenths
Rep Power: 12  | Re: PW Tornado Build pics Side repeaters ,body locators and catches fitted. The side repeator is from a peugeot 505. |
07-06-05, 11:28 AM
#135 (permalink)
| | PDub 6 Tenths
Rep Power: 12  | Re: PW Tornado Build pics Managed to get a Zephyr dash grill in good condition. |
07-14-05, 05:35 PM
#136 (permalink)
| | PDub 6 Tenths
Rep Power: 12  | Re: PW Tornado Build pics Aircon radiator fitted.... |
07-14-05, 05:36 PM
#137 (permalink)
| | PDub 6 Tenths
Rep Power: 12  | Re: PW Tornado Build pics Rear vents arrived - fitted this afternoon. |
07-17-05, 12:06 PM
#138 (permalink)
| | Rookie
Rep Power: 4  | Re: PW Tornado Build pics Paul where did you get body locators and what catches are you using.are they stainless and double catching.Car is looking good.Thanks KEVIN |
07-17-05, 05:35 PM
#139 (permalink)
| | PDub 6 Tenths
Rep Power: 12  | Re: PW Tornado Build pics Kevin,
Body locaters and catches are both from Tornado. |
07-25-05, 05:24 PM
#140 (permalink)
| | PDub 6 Tenths
Rep Power: 12  | Re: PW Tornado Build pics Fitted the rear vents and fog / reverse light for SVA. I will move them once I am through it. |
