Old 02-07-06, 06:46 PM   #41 (permalink)
Frank Beuker's Avatar
Frank Beuker
Silver Supporter
Netherlands
GT40: kva
Rep Power: 7 Frank Beuker has a spectacular aura about
Re: Olivers Ride RF with ZF
does enyone have some experience with making it a drysump and what would i need
frank
Frank Beuker is offline
Old 02-07-06, 07:03 PM   #42 (permalink)
Keith1's Avatar
Keith1
Cayman Islands
GT40: Nein
Hi Frank, there are many threads on this subject that can be searched for on here.
Here's one for example:
Dry Sump
Good luck! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Keith1 is offline
Old 02-07-06, 07:29 PM   #43 (permalink)
SPHameka's Avatar
SPHameka
GT40: RF GT40 #81
Rep Power: 6 SPHameka is on a distinguished road
The Quote should read (see when I blow the track off on your doors) [img]/ubbthreads/images/graemlins/grin.gif[/img]
Looks like you'll have about 8" ground clearance so she should do good off-road. [img]/ubbthreads/images/graemlins/blush.gif[/img]
But seriously you might want to set the rear body on to see if it will clear the engine.
SPHameka is offline
Old 02-15-06, 01:01 AM   #44 (permalink)
Kenny J's Avatar
GT40: Las Vegas, Neva
Rep Power: 4 Kenny J is on a distinguished road
I am also using the same manifold. There is still some finish work to be done.
Ken J
Kenny J is offline
Old 02-15-06, 01:22 PM   #45 (permalink)
Johngt40
CURRENTLY BANNED
GT40: Il.
Rep Power: 0 Johngt40 is on a distinguished road
Were did you get the manifold from! I find hard to believe the manifold it from the same guy. This is only one of four built by this person!
regards
john
Johngt40 is offline
Old 02-15-06, 04:14 PM   #46 (permalink)
emiel
Silver Supporter
Belgium
GT40: kva mk1
Rep Power: 4 emiel is on a distinguished road
I have the ZF from a Pantera in the 40 I bought just like yours Frank.If I had build it myself I would turn transmission because you can mount your engine lower in the chassis.This is a change which is high on my modification list.So if you can ,change it now and, mount the transmission like it was ment to be in a 40.Good luck [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
emiel is offline
Old 02-16-06, 08:12 AM   #47 (permalink)
ross nicol's Avatar
ross nicol
This is the right way up
ross nicol is offline
Old 02-16-06, 08:16 AM   #48 (permalink)
ross nicol's Avatar
ross nicol
and this one ZF mounted in Chassis
Old 02-16-06, 11:02 AM   #49 (permalink)
Frank Beuker
Silver Supporter
Netherlands
GT40: kva
if you lowerthe engine should you modify the bellhouse?
because the way it is now if i putt the zf horizontel i've got only 4 cm between the bellhouse and the floor of the car
Old 02-16-06, 11:04 AM   #50 (permalink)
Frank Beuker
Silver Supporter
Netherlands
GT40: kva
can someone take measurement from the top of the bellhouse till the rearclip
Frank
Old 02-16-06, 03:57 PM   #51 (permalink)
Mark Pickford's Avatar
Mark Pickford
GT40: None
Rep Power: 5 Mark Pickford is on a distinguished road
[ QUOTE ]
Mark,
When flipping a "pantera" ZF, the box is opened and the ring gear is moved to the other side.
[/ QUOTE ]
Thanks for clearing that up for me. My mind was going all swervy LOL
Mark Pickford is offline
Old 02-16-06, 06:18 PM   #52 (permalink)
ross nicol's Avatar
ross nicol
Frank Sorry mate I realize I should have replied to your earlier posted questions.You won't be able to use the Pantera bell housing.My bell housing you can see in the photo is an ERA sourced Item and it has the bottom shaved to be level with the ring gear.It bolts directly to the ZF-2 and allows use of a Standard Ford clutch and flywheel.The ZF can then be mated to a Windsor motor and to set the whole unit low in the chassis you will have to dry sump or get a shallow sump with wings.I can help you with dry sump detail if your still unclear what's required.
Regards Ross
Old 02-17-06, 02:41 AM   #53 (permalink)
Kenny J's Avatar
John,
I purchased the manifold from Steven Morrison from S.D.&L.A.Morrison in Melbourne, Australia.
I meet Steven at the SEMA show last November. He made me a deal I couldn't refuse! I will try to attach a pic.
Ken J
Kenny J is offline
Old 02-17-06, 02:46 AM   #54 (permalink)
Kenny J's Avatar
Here is another view,
Kenny J is offline
Old 02-17-06, 10:17 AM   #55 (permalink)
bchildress's Avatar
bchildress
Gold Supporter
GT40: CAV w/Roush 342
Rep Power: 8 bchildress is a name known to all
Hi Ken,
Your CAV is sure filling with nice details and looking spectacular.
I also have to say that the straight intakes runners on that manifold
look like a modern engineered system that really means business !
Bob
bchildress is online now
Old 02-17-06, 01:23 PM   #56 (permalink)
Frank Beuker
Silver Supporter
Netherlands
GT40: kva
Ross yes please
do you have a picture of the bellhouse (the difference)
and for the dry sump i also thought about dry sumping the zf
Old 03-19-06, 03:26 AM   #57 (permalink)
Neil_t
China
GT40: GOX on the way
Rep Power: 3 Neil_t is on a distinguished road
Hi Kenny
Is there a Kenny's car thread in this section?? If not, maybe there can be Your car looks amazing!
Cheers, Neil
Neil_t is offline
Old 03-20-06, 12:47 AM   #58 (permalink)
561234's Avatar
561234
GT40: SPF MKI #2214
Rep Power: 9 561234 will become famous soon enough
It will work fine, just don't tell everybody what you did!
561234 is offline
Old 03-20-06, 09:22 AM   #59 (permalink)
Johngt40
CURRENTLY BANNED
GT40: Il.
You guys hijacked my thread!!!Please move!!
Johngt40 is offline
Old 03-20-06, 10:00 AM   #60 (permalink)
Frank Beuker
Silver Supporter
Netherlands
GT40: kva
Oliver did you get eny further with your car?
I'm going to flip my zf (as you might have read)
Frank
